White light on upper right corner of 4k tv
(Topic created on: 24-07-2020 04:56 PM)
Marksam
hi everyone, need your help. I just bought a Samsung 65” RU7100 recently and i noticed a white light/spot on the upper right and left corner, is it normal? It’s noticeable in person.
24 REPLIES 24
TessM
Mastermind
Hi @Marksam ,
that doesn't seem right at first sight. Would you be able to tell me is this is appearing in all the channels, apps, and sources?
Marksam
Hi TessM,
it appears in Netflix, Youtube and everything with a black screen on. Should i call service?
thank you for your reply.
AndrewL
@Marksam: Can you go to Settings > Support > Self Diagnosis > Picture Test, and run through this to see if the issue is still present, or if the test returns any 'Failed' messages in the summary. If so, I recommend reaching out to our Help Desk on 0333 000 0333, or using Live Chat via the link below, where an advisor will be able to assist you further.
https://www.samsung.com/uk/support/contact/
Marksam
I already did the picture test but the thing is the picture that is being shown is bright, the light bleeding is only noticeable in black background.
Marksam
CarlH
Ic3man_SLO
Hey guys..any update on this matter ?..I also just bought UE43TU8502UXXH and I have exactly the same issue.
Leaves
I have the exact same problem and my TV doesn't seem to have a self diagnosis feature..
Charlsburg
Pioneer
Did anyone get to the bottom of this issue and whether or not this normal or abnormal? I have the exact same issue. Especially bright corner in the top right, but also existent on top left.  Smaller bottom left and almost nothing bottom right.
