05-12-2017 06:16 AM - last edited 12-03-2018 12:46 PM by AntS ) in
So, of the nigh on 400 TVs supported in BBC iplayer for the Blue Planet II HLG episodes none are from Samsung. Oh joy.
Moderator edit: Original thread title was "Blue Planet 2 HLG - No Samsung". With the OP's permission, the title was changed on 12/03/2018 to accurately reflect the dominant theme of the thread as it has progressed. If the reader would like to know more about the HLG format, please check out the BBC's page and FAQ's on it here: http://www.bbc.co.uk/rd/projects/high-dynamic-range Thank you, AntS.
05-03-2018 03:35 PM
@crashcriswrote:@hdmiunfortuataly that link is not working for me, perhaps you could copy and paste the relevant text. Thanks
which one?
05-03-2018 03:41 PM
This one where you wrote:- Here's official response on Samsung US forum, regardless we will know if Sky HDR/HLG works or not, need to wait
https://us.community.samsung.com/t5/TVs/KS8000-Need-DIRECTV-HLG-support-using-HDMI/td-p/240472
05-03-2018 03:42 PM
@UHDHDR Did you say you were in canada and could you have a different firmware?
05-03-2018 03:45 PM
05-03-2018 03:46 PM
@crashcriswrote:This one where you wrote:- Here's official response on Samsung US forum, regardless we will know if Sky HDR/HLG works or not, need to wait
Try copying and pasting
"https://us.community.samsung.com/t5/TVs/Lack-of-HLG-support/td-p/236704"
and see this as well
05-03-2018 03:54 PM - last edited 05-03-2018 03:56 PM
well thats just not true. The workflows and metadata stuff might change but the delivery mechanism, the one that samsung say can't be done has been defined for years.
http://www.etsi.org/deliver/etsi_ts/103200_103299/103285/01.01.01_60/ts_103285v010101p.pdf
dvb profile for mpeg-dash was sorted out in 2014. this isnt new standard at all. Once the transport gets to the TV then its handed off and the TV does the decode, we cant even get the stream!
not only that but the bbc did a uhd stream in 2014 for the world cup using this same transport.
05-03-2018 03:57 PM
https://us.community.samsung.com/t5/TVs/KS8000-Need-DIRECTV-HLG-support-using-HDMI/td-p/240472Try copying and pasting
I think the consensus on AVS forums is the KS does not recognise the HLG signal as HDR and is clipping it to SDR.
05-03-2018 04:01 PM
@hdmiThanks.
05-03-2018 04:01 PM
That isn't the consensus. Many people are aware of the fact that HLG is supported internally. Fewer people know that it is supported externally via HDMI, but that's been proven to be true as well.
The issue with DirecTV is that DirecTV's equipment is having an issue communicating with the KS series TVs. Since the TV does support HLG over HDMI, this issue could be fixed with an HDfury, which allows for EDID management.
05-03-2018 04:09 PM
@amokukwrote:well thats just not true. The workflows and metadata stuff might change but the delivery mechanism, the one that samsung say can't be done has been defined for years.
That version of the profile is depreciated - the version we're needing to be implemented is the one that handles HLG and was put forward in December 2016.
You're correct otherwise, it's highly likely we'll be able to receive 4k transmissions, but only in SDR. The same situation the Sky Italia peeps are in now.
