09-12-2021 01:58 AM in
WearablesNo incoming ring sounds\notification sounds on phone with Watch 4 connected after watch 4 update on 11/28/2021. I have checked to ensure nothing changed. Nothing muted. I want\need audible ring\notification sounds on phone. With watch powered off, all works as normal. I have reset the watch 4 to no avail. I have sent a support request with no response. Never had this issue with the Watch 3. Watch 4 worked fine (ring\notification sounds on phone worked) until the update. Not sure what I can do other than wait for another update in hopes that it corrects the issue.
09-12-2021 06:57 AM - last edited 09-12-2021 06:58 AM ) in
Wearables09-12-2021 04:23 PM in
WearablesThanks for the reply. I have been through all of those steps. Nothing is muted. Still, no ring\notification sounds on the phone once the watch 4 is powered up and connected to the Samsung phone. Something with the last watch 4 update. I can see that a phone call is incoming on both the phone & watch 4 and I can answer and hear the caller just fine. I just need audible ring sounds on the phone when the the Watch 4 is connected. It worked without intervention prior to the watch 4 update. Samsung is unresponsive.
10-12-2021 03:52 PM in
Wearables@FlyboyLDB: For clarity, does the watch emit a ringtone while it is connected to the phone? On the watch itself, try heading to Settings > Notifications > Mute notifications on phone, and toggle this option off to see if this helps. Also, on the Galaxy Wearable app on your phone, head to Watch Settings > Notifications > Sync Do Not Disturb With Phone, and toggle this option off, if applicable. If you use Bedtime Mode or Theatre Mode on the watch, try disabling these features via Settings > Advanced Features, as they will also mute incoming calls.
