Gear iconx earbuds problems with charging
(Topic created on: 08-09-2019 09:48 PM)
Ceholly65
I am trying to charge earbuds - been charging for more than 2 hours but lights are still red. How long should it take to charge them / light go to green?
4 REPLIES 4
AndrewL
@Ceholly65: At this stage please remove the buds and replace them in their corresponding slots and check to see what colour the LED indicator turns for each bud.
Red = Less than 30% charge
Yellow = Between 30% and 60%
Green = Over 60%
If the LED does anything else, then please let me know.
Ceholly65
I have tried this a few times but both led lights stay on continuous red even when on charge for more than 2 hours
AndrewL
I suppose the good news is that a continuous red LED means the buds are charging, although I would have expected the LED to turn yellow or green after removing and replacing them in the case. Do you have the IconX buds connected to a mobile device? If so can you check the battery level in the Galaxy Wearables app in the 'Info' tab?
Iconx 2018
I ismilar problemi for me. Iconx 2018 plugged under recharge for few hours, Red light both buds, from app they should be 100%, if i try to use them they dont work. Any suggestioni, such as hard reset or similar? Thx
