Galaxy Buds 3 Pro one earbud not charging
(Topic created on: 08-12-2024 12:52 PM)
BasicZero
Navigator
So I've had my buds for a while and for some reason the left earbud is very hesitate to charge while the right one is fine, it charges ever now and then but I've checked the buds and the charging contacts and nothing is wrong with it. Is this a software issue?
15 REPLIES 15
GoanGeek
Samsung Members Star ★★
Have you tried cleaning the contacts? And making sure they are snug in the case?
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
BasicZero
Navigator
Yep
Easty
Big Cheese
I've had the same issue with buds fe and plus , only the left one in both cases , very weird
Samsung Galaxy Note 10 Plus 5g
Samsung Tab S6 Lte 256gb
Samsung Galaxy Watch
BasicZero
Navigator
It's so strange sometimes it charges when the case is wired charging. Currently cleaning it again to see if that's the issue
Easty
Big Cheese
I think it must be a bug , my buds fe played up first , right had 96% left had 8% so put them on charge, thought I'd try buds plus and bugger me the same issue , the buds fe took a good 4hrs to get the left to 100%
BasicZero
Navigator
Now you say that it could be a software bug, because it's refusing to charge because of moisture or foreign material but it still doesn't even register its in the case with it open
Easty
Big Cheese
Same , doesn't connect in ear either
BasicZero
Navigator
Like bt?
Mary-Anne
My Left earbud isn't charging either. Software update won't work.  What did you end up doing? There's obviously a glitch in the system.
