Go to solution Solved
Unable to move Up and Down in settings!
(Topic created on: 13-04-2020 06:09 PM)
krstecd
 I purchased 3 months ago a Samsung 7 SERIES 43 Model: ue43ru7092uxxh TV. Few days ago i tried to change my settings but im unable to do it. When i press the Settings button i can go up and down on the left side (marked with green arrows)  but when i got to the right side (Marked with red arrows) im unable to move up and down and i cant change any settings. I have this problem in the settings only.
It was working when i bought the TV.
2 Solutions
Deea17
Hi I had the same problem with my TV and I called Samsung and they resolved it. All u have to do is to press Info-Settings-Mute-Power on the remote one at the time until you can see a setting menu. Then press on SVC and then factory reset, after that it should get back to normal.
hcf
Finally got this working on my tv (Frame 2018) with only smart remote. When tv is on, find the actual power button on your tv, and hold it down for 5 seconds. Then, hold down the power button on your remote for 5 seconds. The tv should turn off and start a reset process, and after a couple of restarts you should see the setup screen. Now everything is working as advertised for me again :smiling-face:
58 REPLIES 58
CarloL
Hotshot
Hey @krstecd! Can you try restarting the TV? Unplug your TV from the wall socket > Wait 30 seconds, then plug your TV back in > Using your remote, turn your TV on. Also, make sure the TV is running on the latest software version: Menu > Settings > Support > Software update > Update now.
krstecd
@CarloL i tried unpluging my tv and plug in after 30 and more seconds it didn't worked. I just tried to update and its says there is no new update. Current update version: 1356
CarloL
Hotshot
Right, I see. Is this happening on every right menu setting or only on the "right" picture settings? If it's happening on every settings then please proceed with a master reset of the TV: Menu > Settings > Support > Self Diagnosis > Reset.
krstecd
I am unable to go to Settings > Support > Self Diagnosis > Reset.  If i go to Settings> Support the only thing i can use is Software Update, i can't go down or up.
Example: If i want to change Picture Size Settings i will not be able to do it, because i cant sellect it, i cant go down.
Here are some images i made it. In picture settings the only thing i can change is Picture mode because i can't go up or down to sellect, if i press enter to change picture mode i won't be able to move up or down to change the dynamic mode.
Same for general.
Same for Sound
Same For Support i cant do Self diagnosis because i cant sellect it. I was able to do Software update because its the only one sellected when i go Settings> S>pport, and When i press Right arrow on my TV remote > it get Sellected Software remote contorl.
Edit: I have also tried the App Smart Things to go up and down and didnt work too.
krstecd
@CarloL Any solution?
Tags (1)
CarlH
Maestro
Do you have any apps open or any other devices connected to the TV? The greyed out options sometimes appear because of this.
ChrisPollard
Hi I’ve the same model and am experiencing the same problem, did you manage to fix it? Regards Chris
ChrisPollard
Hey did Samsung fix this for you I have the same problem. Regards Chris
ChrisPollard
Did you manage to fix this for the customer? Regards Chris
