UHD770 (i7-13700K) doesn't recognize 3D display ( Samsung UE48H6400 3DTV )
(Topic created on: 17-01-2023 07:14 PM)
Alx24b
https://community.intel.com/t5/Graphics/UHD770-i7-13700K-doesn-t-recognize-3D-display/td-p/1445852
"UHD770 (i7-13700K) doesn't recognize 3D display"  ( Samsung UE48H6400 3DTV )
https://www.intel.com/content/www/us/en/support/articles/000091520/graphics.html
Article ID: 000091520
Content Type: Product Information & Documentation
Last Reviewed: 07/28/2022
Is Stereoscopic 3D (S3D) Video Supported on Intel® Arc™ Graphics or 12th Generation and Newer Platforms?
Summary
Description
Resolution
Summary
Information for Stereoscopic 3D (S3D) support on 12th generation and newer platforms including Intel Arc Discrete graphics
Description
Do the new Intel® ARC™ discrete graphics support 3D / quad-buffered stereoscopic rendering on Windows® 10/11?
Resolution
Stereoscopic 3D (S3D) support is discontinued from 12th generation Integrated Graphics and newer platforms including Intel Arc Discrete Graphics cards.
This results in the option in OS Display settings page for “3D Display mode” to be unavailable.
This article 000091520 was a supplement to the main 000030190 article that referenced it
https://www.intel.com/content/www/us/en/support/articles/000030190/graphics.html
Intel® Graphics Support for Stereo 3D (S3D) Technology
Documentation
Content Type
Article ID
000030190
Last Reviewed
08/01/2022
The stereo 3D (S3D) technology has been and continues to be supported on Intel® graphics via HDMI 1.4.
On some original equipment manufacturer (OEM) PC designs with 6th, 7th, and 8th Generation Intel® Core™ Processors, a LSPCON is used to convert a DisplayPort 1.2 signal to enable HDMI 2.0. This is a third-party integrated controller on the motherboard, and S3D is not supported in this scenario.
Our OEM partners have moved away from enabling this feature based on low customer demand. So S3D via HDMI 2.0 isn't currently supported on some 6th, 7th, and 8th Generation Intel® Core™ Processors
Related topic
( https://www.intel.com/content/www/us/en/support/articles/000091520/graphics.html )
The 000091520 article was later deleted and the main article 000030190 modified as follows:
Support
Documentation
Content Type
Article ID
000030190
Last Reviewed
11/03/2022
Related Products
This article applies to 21 products.
Intel® Iris® Graphics 540
Intel® Iris® Graphics 550
Intel® Iris® Plus Graphics 640
Intel® Iris® Plus Graphics 650
Intel® Iris® Pro Graphics 580
Intel® HD Graphics 500
Intel® HD Graphics 505
Intel® HD Graphics 510
Intel® HD Graphics 515
Intel® HD Graphics 520
Intel® HD Graphics 530
Intel® HD Graphics 610
Intel® HD Graphics 615
Intel® HD Graphics 620
Intel® HD Graphics 630
Intel® UHD Graphics 610
Intel® UHD Graphics 605
Intel® UHD Graphics 620
Intel® UHD Graphics 630
Intel® UHD Graphics 615
Intel® UHD Graphics 617
Show less
From the list of "Related Products" it follows that Intel Stereoscopic S3D (Windows DirectX 11 Stereo) is available starting with Intel HD Graphics, HD 5xx, HD 6xx and beyond are missing from unlisted HD 7xx and equally new graphics devices.
Later, another additional article appeared, confirming all the previous information:
https://www.intel.com/content/www/us/en/support/articles/000093215/graphics.html
Intel® Integrated and Discrete Graphics Driver Support for Stereoscopic 3D is Discontinued from the 12th Gen Intel® Core™ Processor Family (Formerly Known as Alder Lake) Onwards
Documentation
Content Type
Article ID
000093215
Last Reviewed
12/09/2022
The Intel® Graphics Drivers for the 12th Gen Intel® Core™ processor family (Formerly Known as Alder Lake) and onwards, including Intel® Arc™, will discontinue the support for Stereoscopic 3D.
Related Products
This article applies to 12 products.
Intel® Arc™ A-Series Graphics
Intel® Arc™ A350M Graphics
Intel® Arc™ A370M Graphics
Intel® Arc™ A380 Graphics
Intel® Arc™ A750 Graphics
Intel® Arc™ A770 Graphics (16GB)
Intel® Arc™ A770 Graphics (8GB)
Intel® Arc™ Pro A30M Graphics
Intel® Arc™ Pro A40 Graphics
Intel® Arc™ Pro A50 Graphics
Intel® Iris® Xe Graphics
Intel® Iris® Xe Graphics eligible
Show less
The detailed documentation of Intel Corp. for latest Intel Core Processors notes:
Display Technologies Support
HDMI 2.1 High-Definition Multimedia Interface Specification Version 2.1
Notes:
Processor support native HDMI 2.1 TMDS compatible ports
Processor support non-native HDMI 2.1 port by using DP to HDMI protocol converter.
DP to HDMI protocol converter is also called LSPCON and it is used to convert DP signals into high-resolution HDMI 2.0 and HDMI 2.1 signals
His presence makes impossible Intel Stereoscopic S3D and its presence or absence is determined easily and quickly by the program
"Intel Graphics Control Center" from the Intel Corp. graphics driver package when generating a report file.
In the case of the above-mentioned intel community question from the "ssu.txt" file of the Intel® System Support Utility for Windows* report ( or Windows DxDiag report, or Intel Graphics Command Center -> Display -> Information -> Connector Type ), it appears that this ASUS PRIME Z690-P motherboard does not use LSPCON, and the absence of "3d display mode" is determined by the absence of it in the graphics of the 13th Generation Intel processor
Card name: Intel(R) UHD Graphics 770
Output Type: HDMI
0 REPLIES 0
