TV stuck on one channel
(Topic created on: 30-07-2020 10:02 AM)
Rasputin46
Quite often when I turn on my TV it is stuck on the last channel I was watching the previous day.
All other functions are working. I have two remotes so that isn't the problem.
I have checked for firmware updates of which there are none.
The model is UE32M5520AKXXU bought just last year
8 REPLIES 8
ChrisM
SuperStar
Hi @Rasputin46
Could we take the current software version of your TV? Go to Home > Settings > Support > About This TV. Also, have you tried a reset on the TV? Go to Home > Settings > Support > Self Diagnosis > Reset > PIN. Note, all settings on the TV will revert to factory default settings.
Rasputin46
I have been doing this reset about twice a week to no avail.
I was on to Samsung chat about it and they told me that after doing a reset I should also turn off the standby auto tuning. I've now done this so we'll see what happens over the coming days.
ChrisM
SuperStar
No problem, @Rasputin46. Let us know how you get on!
Rasputin46
So far so good, hope it remains this way.
Rasputin46
Well, it looks as if my problem is solved
MissE
I regularly have this problem with my Samsung TV, I've had it 5 years, I'm pretty sure it's always done it, its very annoying, it also randomly cuts out during a programme too!
80Ruffles
This seems to have worked for me too, thanks!
Evamonroe
I tried everything listed. Nothing works but this remote works on other tvs so its not the remote. When I got to reset It’s asking for a pin. Where do i find the pin?
