Go to solution Solved
Product Registration UE43TU8000KXXU
(Topic created on: 10-06-2020 09:04 PM)
Countyfinal
I recently purchased this TV but when I go to register the product the TU8000 series is not available for selection.
How do I register the TV?
Countyfinal
Hi Chris,
I was trying it on a Smart Phone and not all the options were showing up when I was scrolling. I found the correct product when I used my PC.
All registered now.
Thanks for replying.
7 REPLIES 7
ChrisM
SuperStar
Hi @Countyfinal
Did you manage to get this sorted? Where are you trying to register your TV?
Countyfinal
Hi Chris,
No I haven't got sorted. I'm using https://www.samsung.com/ie/support/warranty/ but the 2020 43 inch TV is not listed.
Countyfinal
Hi Chris,
All registered now.
Abigail93
I'm unable to get through on the phone. I have no access to a pc. on my phone my modle 49 inch series 7 curved is not there. what can I do?
Abigail93
I also have a sound bar HW-T400. asking for serial number. where do I find this?
AndrewL
@Abigail93: The serial number for your soundbar can be found on a sticker on the back of the device itself, usually located above the barcode. Look for the reference 'S/N' and you should be good to go.
Countyfinal
my model only appeared when I did registration on a PC. Model did not show up when doing registration through a Samsung mobile phone.
