03-12-2021 01:42 PM in
TVWe have recently purchased a QE32Q50A TV, sometimes after turning the TV on from standby there is no TV sound BUT menu sounds work okay. If we turn the TV off either with the button underneath or at the wall socket then it starts to work. But frequently fails again after the TV has been in standby.
Anyone else suffered similar issues?
03-12-2021 03:37 PM in
TVHi @Ska Dog Chris check you have the latest software which is 1805.4 which was released in September. However as the Tv was purchased recently I suspect this is the case. if not it can be updated via USB as shown here https://www.samsung.com/uk/support/model/QE32Q50AAUXXU/ Otherwise you could try the following: Go to Settings > Support > Self Diagnosis, select Sound Test. Depending on the result you may need to reset the sound via settings-Sound-Expert Settings.
However if this does not provide a solution I would advise a factory Reset to see if that makes a difference. Settings-Support-self Diagnosis-Reset.
One Ui 5.0,Android 13 .
03-12-2021 03:44 PM in
TVthanks for the tips JAMES4578, as you say I believe the latest software is installed but will try a factory reset over the weekend. It passes the sound test when the issue occurs.
03-01-2023 11:47 AM in
TV03-01-2023 11:49 AM in
TV12-03-2023 09:34 AM in
TVHi Jimfred. Did you resolve this? I bought mine just a couple of weeks ago and it’s at the latest firmware version but am also experiencing this exact issue.
24-03-2023 10:12 PM in
TVSame issue, unable to resolve
29-03-2023 04:39 AM in
TVI’ve also got the same problem. Got the tv a few weeks ago, exchanged it for a new one, same model but still have the same issue. Seems to fix when I turn it off and on again but still not ideal, especially for the cost of the tv. Sound test returns no issues. Would be great if there was a solution.
2 weeks ago in
TVSeems as though I am following the same path as you. Bought it on Monday, sound was an issue from standby on day two. Thought I'd ignore it. Now can't as it's on the wifes radar. Happened again this morning and will be returning TV - currently have the most up to date operating system and followed all the self diagnosis tests as recommended by Samsung
