03-12-2021 11:07 AM in
TVYour |
Hi there everyone, I hope someone can help me with this rather annoying issue that has started to happen to me in the last month..... I own a Qe65q9fna TV. I have a bang & olufsen soundbar attached to my TV using the correct hdmi cable via the hmdi arc connection. This has worked correctly for 1 year. Within the last 1 month my sound has been switching off at 3 minutes.... And as no signal to my soundbar it goes into stand by mode. When I go back to the TV speaker that works fine then back to the sound bar it works for 3 minutes again. The firmware on both my TV and sound bar are up to date. And the cable is connected correctly and worked fine for a year. My TV is 3 years old and has 2 remaing years warranty left. I would love to hear if anyone else has had this issue or any ideas to resolve this issue. I'm starting to lose faith in the Samsung brand at this stage. Kind regards Wess |
03-12-2021 12:09 PM - last edited 03-12-2021 12:10 PM ) in
TV03-12-2021 12:29 PM in
TVThan k you ornyour help. I have read this article already. My issue happens when watching TV. Sound is working then boom right on 3 minutes the sound bar goes into stand by mode. I'm forced to use my TV speaker until this issue is resolved.
05-02-2022 07:20 PM in
TVHello, did you find a solution to this problem regarding your soundbar going into standby after 3 mins? I have the same setup as you & the exact same thing is happening. So annoying. Please let me know.... thanks...
06-02-2022 10:33 AM in
TVHi there, yes I found a solution in the end. It's an issue with the firmware on the bang and olufsen soundbar. Contact them and they will ensure your firmware is updated. They seemed aware of my issue and very helpful. I was switching my speaker off at the mains but now I leave on standby mode to allow firmware updates to take place. You can also update for your firmware to be automatically updated when updates become available on the B & O APP. Contact them and they'll sort you.
06-02-2022 01:04 PM in
TVMany thanks for replying. I will do a firmware update & contact B&O as you suggest & hopefully will get it sorted. Thanks once again 👍
27-04-2022 09:06 PM in
TVI have this exact issue between Samsung TV Neo QLED QN90A and Beosound Stage. At around 3 minutes the soundbar starts by just turning off then it turns the TV off. Extremely frustrating. How do you update firmware if auto updates are already on?
