03-12-2021 10:30 PM
Hi,
I want my brand-new TV to autoconnect to my Bluetooth speakers on startup, without me needing to confirm the prompt. This is annoying as hell...
Could not find any solutions in the forum thus far, only people facing the same problem.
Thanks!
Regards
Stefan
04-12-2021 10:07 AM
Hey @Suebbing ,
happy to have a look at this with you. Can I please take the TV and speakers model? On our devices, you can find the model at the back on a white sticker.
04-12-2021 11:35 AM
Hi,
the TV is a 2021 Frame 65"
G065LS03AAUXZG
and I am using a Google home max as a speaker.
Regards
Stefan
04-12-2021 02:02 PM
Thanks for providing me with that @Suebbing. While I was waiting for your response I have found this thread that may respond to your question: https://eu.community.samsung.com/t5/tv/auto-connect-to-bluetooth/td-p/1600988
04-12-2021 02:20 PM
Hello,
Yes I've read this thread already, all it says is that you would always have to confirm the prompt on startup, but this cannot be the solution. Samsung should really implement this feature, the required effort for this is minimal.
04-12-2021 02:28 PM
That seems to be the case at the moment @Suebbing. I will ensure that this is fed back internally for any future upgrade.
20-12-2022 10:36 AM
Any update on this feature? Still has not been implemented. It is soooo annoying having to confirm the prompt every time I startup the PC, and it makes it worse when you click the wrong button on the prompt and have to go into settings
23-01-2023 06:52 AM
I am also facing this issue. I have 55q60b and Mi SoundBar. Everytime after poweron, tv asks if I want to connect to soundbar, and I have to press "Connect". This is super annoying. Is there a fix for this.?
14-02-2023 01:34 AM
Same issue here. I agree with people saying they wouldn't buy another Samsung TV because of this, we didn't realise when we were buying it that the TV only outputs audio via Bluetooth and has no aux output- what a horrendous design. Please, please fix this
29-03-2023 11:28 AM
Hello Samsung
I also have this problem, please implement the auto connect feature (without interaction). Its very annoying!
