I can’t connect my Nintendo Switch to Samsung TV.
(Topic created on: 04-04-2020 05:27 PM)
Asylum_Demon
49 REPLIES 49
Dan_1989
This is the same for me at the moment too!
CarlH
Maestro
Hi. In your Switch System Settings, Go to TV output and change the RGB Range from Automatic to Limited. Does that fix the issue? From this thread
Dan_1989
Hi, yes I do get a picture but it isn’t recognising the switch as a console. Just an unknown hdmi connection so game mode isn’t turned on automatically etc. Thanks
Stursh
I am having the same issue. Tried redoing all the settings and nothing from the switch. It works on my other newer TVs so I know it isn't an issue with the cable or docking station. TV is a 2010 Samsung LN32C450E.
Speter67
Perfect solution !
Thanks!
AbhinavD
Nah..it still didn't work out....btw it was working perfectly until yesterday
Nayolk
This 100% worked for me!! So happy!! Try this!!
Sanchimoto
Not sure if you’ve solved this but here what I did.
1. Unplug everything from the TV.
2. Remove power plug (I waited 10 minutes).
3. Plug TV in and reset TV by holding power button on remote until Samsung logo comes up.
4. Verify HDMI settings are correct in system settings.
5. Plug in Switch (I used HDMI 1) and power on
at this point the TV quickly detected my Switch and labeled it as such, also restoring the swap to game modeON when the Switch is turned on.
After that I plugged in the rest of the home entertainment items and have had no problems.
Ann1973
Thanks that worked for me. Was driving me crazy lol..
