Go to solution Solved
QE65QN85D - If connected to a Freesat Recordable set-top box can I still access the Samsung tv apps, in particular, NowTV ?
(Topic created on: 01-04-2025 05:11 PM)
Ryston17
Good afternoon all,
I have the above tv and is connected to a Sky Q box. Price-wise Sky is getting too expensive and I am looking to go back to Freesat.
My question is - If connected to a Freesat Recordable set-top box can I still access the Samsung tv apps, in particular, NowTV (for Sky Sports)? (Freesat does not have this app)
Furthermore, would I be able to record NowTV programmes?
I would appreciate any information
3 Solutions
JAMES4578
Samsung Members Star ★★★
Hi @Ryston17  Welcome to the Samsung Community  :smiling-face:
yes you can access the Tv apps regardless via the Source option,  cannot record apps via USB/external Hard Drive due to DRM  (Digital Rights Management)  .   However certain shows are available via catch up or Box sets with Now TV Entertainment Membership.  https://help.nowtv.com/article/can-not-find-show-i-am-looking-for
For Sports think it is just selected catch up which may well just be highlights.
Ryston17
Hi JAMES4578,
Thank you. Much obliged for your answer.
JAMES4578
No problem, hope it helps 😊
3 REPLIES 3
JAMES4578
Ryston17
Hi JAMES4578,
JAMES4578
