HD channels on smart TV has disappeared.
(Topic created on: 25-10-2020 11:19 PM)
Robin63
I have a 50” HD Smart TV, about six years old. It could receive all the HD channels available in my region, but it has suddenly decided to lose them all and I cannot seem to find them again. I have performed auto tune and manual tune but still no HD channels. In my area the HD channels are available on channel 21, however when I try to manually return and find channel 21 it finds nothing. I know it is not a problem with aerial because I have swapped it with another TV and that works perfectly well. Can anyone suggest any solutions?
19 REPLIES 19
PaulyWauly36
Pathfinder
reset to factory settings via menu
Nikita69420
Pioneer
are you using any sort of freesat box or free view?
Robin63
I am using a normal aerial receiving TV signals through the air. There is no freesat box, but I do have Freeview. All the TV I get through the aerial is free to view.
I have retuned a million times and still HD channels. I have swapped the TV with another one and tuned that perfectly. When I try to tune the existing set it simply will not find any HD channels. All the SD channels are fine.
Robin63
Thank you. I have done that to to no avail.
claus4
Do a Master reset
Robin63
Thank you for your suggestion. Can you explain what a Master reset is? I have done a Factory reset. Is that the same thing?
claus4
can you tell me where you live ,i had something similar and i honed Samsung the referred me to ISL IN KETTERING A TV REPAIRER THE SORTED IT FOR ME AS I LIVE IN NORHAMPTONSHIRE
claus4
what model is your tv
Robin63
Thanks Claus4. I live in New Forest, near Southampton!
