How to view Channel 3
(Topic created on: 05-02-2025 04:04 AM)
Vernal Bogneris
I have a QN90B and I want to connect a Super Nintendo, which only uses old school coaxial connection. Great. It's all hooked up. Now if I could only find Channel 3 on this oh so very clever Smart Ass TV. Seriously though. The TV has a coaxial input. The user manual shows how to connect the coaxial cable, but does not describe how to ACCESS the input from that cable.
When I view or try to edit the channel list, I can not go below channel 1000, i.e. Samsung Plus channels.
I tried using the auto-program feature to scan for active channels, but it's greyed out and not available.
I realize that in this day and age, it's all about apps and streaming, but the TV DOES have a coax input. It just doesn't tell me HOW to access that input.
Someone, anyone, please help. Thank you.
1 REPLY 1
eeeemang
I see it has both an Analog Tuner as well as a Digital Tuner used now for over the air TV.
found that here
This page has User Manuals
good luck
I used google to search the model number you posted.
