Problem with auto dose -fabric softener compartment.
(Topic created on: 06-07-2023 05:50 PM)
LondonUser82
I have a 2021 Samsung washing machine with the auto dose dispensing system. It's worked fine since I got it (just over a year ago),  but in the last few weeks the fabric softener compartment empties completely after a was or two (or a day or two, haven't figured out which of the two it is). I've taken the auto dose drawer out and cleaned it, as well as the inner part of the washing machine it fits into, with no success. Can someone help please?
8 REPLIES 8
ChrisM
SuperStar
Hi @LondonUser82
Did you manage to get this sorted, or are you still having the same issue?
LondonUser82
Hi @ChrisM .
Thank you for the reply. No. It just happened again last night. I had just refilled the fabric softener container and it's now empty after having used the washing machine on a short cycle (with the fabric softener feature deactivated). Any suggestions?
AndrewL
@LondonUser82: Please can you confirm the model number of your washing machine, located on the sticker on the inside of the door or drum, and I will look into this for you.
In the meantime, please can you try turning the Navigation Dial on your machine, select 'Dose Per Wash' or 'Dose Per Rinse' and explore the available options. For further guidance, please take a look at the guide below and tap on 'How to turn on auto dispensing (front load)'
https://www.samsung.com/us/support/answer/ANS00088882/
LondonUser82
Thank you. The model number is:
WW90T684DLE - Washing machine AddWash™ Series 68, 9kg, White
CarlH
Thanks @LondonUser82. Did you manage to look at the guide Andrew sent?
LondonUser82
Hi Carl. Yes, I had a look at it. I already know how to adjust the general as well as the day to day settings for the fabric softener. I actually did a "reset to factory settings" this morning. Hopefully that might help..?
AlrightElephant
We’re actually having the same issue. We’ve had the machine for about 6 weeks and it needed filling every 1-1.5 weeks. Suddenly it needs filling after two washes and it’s going to bankrupt us! It’s a Series 5+ WW90T534DAW
Members_qv6nCh0
Hi @LondonUser82 I've been having these issues for approx 6 weeks now.  Started out with just the softener and is now both softener and detergent.  I Carried out all the steps of checking dose for detergent and softener which are both set to Low, washed out the drawer and drawer compartment and all valves etc. to no avail.  Did the factory rest solve your issue?
