Wall Mount Screws for 32” Q50A QLED Full HD HDR Smart TV
(Topic created on: 21-12-2021 11:38 AM)
Jonjon101
I may have made a mistake and got a 32" Q50A as I wanted to hang it on the wall, but the screws I had did not fit so called Samsung help line who unhelpfully told me the wrong size. So now I don't know the right screws to order and after 4 weeks still don't have this tv up and working. If anyone can help me please with something in the UK.
Thanks
8 REPLIES 8
xSteveuk
Mastermind
Hi,
This may be helpful
There is always a universal TV mounting screw kit available.
For TVs 19 - 22 inches, the screw size is M4.
For TVs 30 - 40 inches, the screw size is M6.
For TVs 49 - 88 inches, the screw size is M8
Jonjon101
Thank you
Matt T
Just in case others are reading this - the correct mounting bolts on  this TV are actually M4.  Depth of mounting holes is given as 19mm to 22mm (you can find this information in the 'quick set-up guide'.  I used M4 20mm bolts and these worked fine.
Cam7781
I have tried all M4 bolts, 4mm screws and even tried imperial equivalent as last resort…nothing fits. M6 is too large as that’s what everyone states must be used for 30-40” mounting. M4 come as standard .70 pitch not 1.25. M6 are 1.25 pitch but as said previously don’t fit
Nissar1
I bought the M6 screws for my Q60C but they are a little big. Any suggestions?
David30000
I have the same problem with the same TV model Q60c 32
Nissar1
How did you solve the problem?  Is there a special M6 screw available for this job or did you use something else. Thanks
Nissar1
Standard M6 screws don’t work. Someone said you need one with a 1.25mm pitch which is the gap between the threads. Can’t seem to find it anywhere online or in stores.
