17-05-2024 04:02 PM
Hello!
Can any please clarify what size (length) of M8 screws required by SAMSUNG manufacturer for UE55F6640SS TV - VESA mount? I don't want to damage the TV screen.
Maybe is there any original schematic (instruction) of options?
Thank You!
17-05-2024 05:39 PM
17-05-2024 06:32 PM
I'm a little confused because local Samsung support recommends screwing in M8 - 45 mm screws for this model, but then I'll look at the ends of these screws instead of the picture. I don’t expect that Samsung will complete the devices with everything, but I would like to get complete information on the recommended parameters for this device. Yes, the device is not the newest, and of course, with respect to new models, everything may be different ...
17-05-2024 06:43 PM
@Lacicor: The Quick Guide for this model (linked below) recommends standard M8 screws for VESA specified wall mounts, which is 45mm. For clarity, please see page 19.
17-05-2024 07:41 PM
Thanks for the answer. Yes, I saw this document, but it was not clear what exactly the size of the bolts was. not a single mention of length 45mm. Common lengths for M8 screws range from 20mm to 45mm.
28-06-2024 11:05 PM
I just ordered some of these from a company called bolt base for my QE55S92CATXXU, sinc they are allen key type they will be good for getting in to tighten or loosen when the TV is on the wall. 10.9 High Tensile Self Colour Socket Button Head Screws | Bolt Base
Can't wait to get it up when they arrive to me. Will also get the wife off my back🤣
