Frame tv with feet
(Topic created on: 16-05-2024 04:49 AM)
Akricha
Can I use a frame around the tv while using the feet?  I will be mounting the tv eventually but in the meantime I’m using the feet. They don’t slide all the way in due to the large frame, I just want to make sure this is safe/stable temporarily.
7 REPLIES 7
Gurky
Helping Hand
Yep, I don't see any reason why not? The Bezel doesn't hit the feet.
Akricha
I’m not using the bezel frame, it’s a 3” frame that does hit or rest on the feet a bit
Gurky
Helping Hand
Shouldn't rest on the feet? They lock into the back of the TV .
Akricha
Not with a frame that wide, hence my question.
Gurky
Helping Hand
I'm sorry, do you mean the Bezel on the Frame TV or a 3rd party "frame".
If you mean a bezel around the TV while using feet yes you won't have an issue Samsung make the feet and the bezel so designed to work together
Akricha
It’s a 3rd party frame
Akricha
