Frame TV HDMI max length
(Topic created on: 16-05-2024 01:52 AM)
Wyatt Craig
Does anyone know the maximum length HDMI cord you can connect to the one box? When I plug up a 6’ cable it works but I’ve tried 3 others that are 50’ length and it says no signal.
1 REPLY 1
Gurky
Helping Hand
I have a 6m so shy of 20ft? Plugged in, in theory you can get away with upto 50ft/15m before the single degrades to far, I also imagine for a PS5 needing max bandwidth you'll need to be careful for a say 1080p PC can push it.
Going longer you'll need optical HDMI with a repeater i think!
