09-02-2025 10:37 AM
I have a problem with my Samsung 50" The Frame. When I have it connected to my PC and disable projection, the TV keeps trying to reconnect, which causes lag on the computer.
What I have tried so far:
I would gladly appreciate any tips that could help me solve this problem.
Solved! Go to Solution.
09-02-2025 05:22 PM
It turned out to be a compatibility issue with the cable. I swapped it with the one I used for my other TV, and everything worked as it should.
09-02-2025 05:22 PM
