09-02-2025 01:34 PM
Is it possible to install 3rd part apps on samsung tv on du 7000
09-02-2025 02:05 PM
09-02-2025 02:25 PM - last edited 09-02-2025 03:20 PM
@Abdosaid: Further to the above, it will only be necessary to install apps on an external USB storage device if the TV's internal storage is insufficient. To install apps on the TV, including supported third party apps, simply head to Home > Left directional button > Home (house symbol) > Apps > Move to the app you want to install > Press the Select button > Install. To search for apps, use the Magnifying glass symbol in the menu bar on the left side of the screen.
