S95D loses connection to Xbox X when HDR is activated
(Topic created on: 17-01-2025 09:12 AM)
Arvidw
Hi,
I'm experiencing an issue with my new 55" S95D when starting games on my Xbox X.
Starting up the Xbox works fine. And i can see that the HDR is inactivated, using the game mode quick settings menu, while I'm in the Xbox start page/home view.
But when i choose to start a game, the window goes black for about 3 seconds and then the tv claims the external unit is not powered. Which I believe is triggered when the HDR is activated.
I've tested three different HDMI cables. One is the Xbox included one and the other two is HDMI 1.2 Ultra High Speed cables. 0,5m and 2m in length.
My gut feeling is this is software related somehow, maybe conflicting settings?
Any one that experienced the same or have any suggestions of potential solutions?
Thanks!
#s95d
9 REPLIES 9
Obsydian
Samsung Members Star ★
Hi and welcome, occasionally i still get this issue with Sky Q (...unit not powered on, I have to switch it off from the plug), I found the more competing connections you have, the more likely a problem, I used to have a Firestick, Apple TV and USB plus Sky Q connected, was a pain as Apple and the Firestick always fighting for control of the input.
2 Decades Samsung Ownership, Follow me on Instagram Obsydian_SMS
DAILY: S25 Edge, ZFold6, Watch Ultra, Fit3, CL Ace 2, BT-W6, 20,000 Power bank, Smart Tags
FAMILY: ZFlip5, ZFlip6, Watch6 Classic, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFlip4, ZFlip3, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
AndrewL
@Arvidw: Does the picture return after launching a game, or does it remain blank? Have you tried pressing and holding the Power button on your Xbox to perform a Soft Reset, to see if this helps? If it doesn't, try an alternate HDMI port, just in case there is an issue with the current connection.
Arvidw
Ah, ok. i only have the apple tv and the xbox connected, and they tend to be not be powered at the same time. So not sure if there is a control of input fight going on. Do you have any of your issues that might be connected to HDR content? My 'feeling' that it's when the source goes from SDR to HDR that it occurs.
Arvidw
It goes black for 5 seconds and then the 'External device not powered' screen is showing on the tv. With the option of 'Turn on device' which instead turns of the external device, since it's already on.
It has occurred in three separate ports, but once it worked when i disconnected the HDMI and re-connected it to the same port.
Not happening every time though.. so it's all a very spooky kind of issue
Cptncallaway
Hi. Did you solve this as I’m having the same issue. Thanks.
Jason A
I am having this issue for a while now.  I have switched cables…no help.  It’s super annoying.  Anyone fix this yet?
Cptncallaway
I replaced my cable with this 8k one and it’s not dropped out since!
HDMI 2.1 Cable... https://amzn.to/4ihQlkq
Jason A
Great!  I will try that.  Thanks!
Arvidw
Hi all,
After conversations with Samsung support I 'pulled the plug' on the connect box and left it without any power for a couple of minutes for it to be reset. And since then i haven't experienced the issue again. So recon it was some software glitch that was the cause of my issues.
