What is the required M8 screw length for mounting a QE55S92CATXXU TV to a VESA wall bracket?
(Topic created on: 22-10-2023 12:25 PM)
mattworcester
Can someone let me know what M8 size screws I need for me new QE55S92CATXXU The quick guide says 28-30mm but cannot find these ones on amazon 😞
5 REPLIES 5
papashaun
Troubleshooter
If in UK would prob be able to get from Screwfix / B&Q / local hardware shop or autoparts store etc
AlexLdn
Voyager
Here are some M8 30mm https://www.amazon.co.uk/Bracket-Phillips-Screws-Samsung-Philips/dp/B091FS68KY/ref=asc_df_B091FS68KY.... Is it hard wall or plasterboard you are putting the TV on? If it is plasterboard I recommend this
TOGGLER M8 Snaptoggle https://www.tcfixings.co.uk/product/toggler-m8-snaptoggle-m8-x-60mm-hex-head-screw-4/14582?gclid=Cjw...
Members_6bidI86
Hi, thank for the M8 screw size, do you know the spacer size required?
AlexLdn
Voyager
No idea sorry. But in my TV I had a template of the holes
Members_Uru7K0m
I found these screws on a site called bolt base, they will do the same thing, ordered the m8x30 10.9 High Tensile Self Colour Socket Button Head Screws | Bolt Base
Also found these spacers on their site so order a couple of lengths of the m8's so that i have options. White Nylon Plastic Spacers M2.5 - M12 | Bolt Base
Hopefully have the TV up next week at some point.
Hope this helps.
