12-07-2024 02:01 PM
Please help! I recently bought a Samsung Crystal UHD CU7095 43 inch TV and the screws that came with it for the base are too big. They start to screw in then get far too tight and will not go in all the way. I asked Samsung Support which screws are correct and they are telling me M8 20-22 mm, but those seem far too large. Can someone help? What are the correct screws for the base (NOT a wall mount, just the legs that come with the TV)? Thank you.
12-07-2024 03:04 PM
13-07-2024 12:57 PM
I just ordered a set of different sized screws and washers, so we will see. The screws that came with the TV are slightly too tight (you can start to screw them in, but they get stuck before are screwed all the way in.) But when I asked Samsung support directly, they told me size M8 which is WAY too large. I think they were thinking of the wall mount. I just want to add the tv stand legs that come with the TV!
13-07-2024 01:00 PM
13-07-2024 01:03 PM
Thank you. If none of the screws I ordered work, I'll try adding some washers!
13-07-2024 01:04 PM
