UE75TU7005 magic remote\smart remote
(Topic created on: 18-03-2021 08:06 PM)
nonnus
Hello... I have this 75 inch samsung UE75TU7005... I wonder if there is a smart remote\magic remote compatible to this tv model??!! If not, is there another possibility??! 😕
4 REPLIES 4
AndrewL
@nonnus: It looks like this model comes packaged with a Smart Remote which has Universal Remote capabilities, allowing it to control registered external devices. I hope this helps.
nonnus
Thanks for reply... I mean, like having the microphone to speak any command, like bixby?
AndrewL
@nonnus: Yes, the Smart Remote has a microphone button that allows you to use voice commands via your chosen Voice Assistant, including Bixby. To find out more, please check the link below.
https://www.samsung.com/global/tv/blog/the-one-smart-remote-you-will-probably-ever-need/
nonnus
Yes, that is the remote (One remote), I just need to know if it is compatible with my tv model... my remote is the regular black remote with the capabilities you mention earlier
https://images.samsung.com/is/image/samsung/pt-feature-find-a-variety-of-content-with-one-remote--eu...
