Go to solution Solved
Smart TV captions are stuck on the screen
(Topic created on: 30-12-2018 01:57 AM)
Rich-n-Lin
TV
I have tried to get the two lines of frozen closed captions that are old ones off the TV screen.  I’ve unplugged the TV and disconnected everything in the back and it’s still there. First it was one line and a week later a second line. I’ve turn off the closed captions but both lines are still there.  Anyone have any ideas what to do?
Lubeatco
TV
I have discovered two methods to get rid of the stuck closed caption phrases that work for me!.
1)  Uplug TV from the wall let it sit for a few seconds 15 or so then plug it back in.... the stuck captions are gone.
Method #2
2)  Using remote, Turn TV off for about 15 seconds.. no need to unplug. Turn TV on ..(don't worry about captions still there). Then   Turn TV off again for about 15 seconds....... Turn TV on again.... This time you should see the Smart TV heading..  When the Smart TV  heading clears  the stuck  captions  will have also cleared!
The problem is the captions keep getting stuck on the screen!  So for me, it's easier to turn the TV on and turn off as it takes about 30 seconds rather than unplugging the TV from the wall frequently!
I hope one of these methods works on your television!
28 REPLIES 28
Bake65
TV
Similar problem here. I have 2 letters of frozen closed captioning text that I cannot remove.
Bake65
TV
Saw on another forum that updating firmware can fix the problem.   Now I need to figure out how to update the firmware on a tv in a home w/o internet connectivity.
CarlH
TV
@Bake65 and @Rich-n-Lin. Can you tell me the model number of your TV and the currentt software version you're running? This can be found by pressing Menu/ Settings on your remote and going to Support > Sofware Update.
Bake65
TV
Sure
TV is UN55SJ7000
Current Software is 1464.
TV says new version is 1530.
CarlH
TV
Thanks @Bake65. Are you based in the US? This model isn't a UK one.
Rich-n-Lin
TV
Model code is :UN65M4650D
vesion is :1250
Edith_LV
TV
I have the same problem right now.  Caption stuck on the screen.  Did you figure it out how to get rid of it?
ChrisM
TV
Hi all. It's important to check that the software on your TV's is up to date. This can be done through the menu of the TV, if it's connected to the internet, by going to Support > Software Update > Update Now.
If it states there is no update available, bring up the Samsung website on a PC/laptop, enter the model code of your TV into the search bar and once you've brought up the web page for your TV, scroll down to the the 'Download' section towards the foot of the page, where there's a link to download the latest software version to a USB stick with instructions. This can then be plugged into your TV and downloaded.
Let us know how you get on.
Eberu
TV
I have done the UPDATE ..STILL NO CHANGE!! I STILL HAVE 2 FOZEN LINES..HELPPPPP
