Go to solution Solved
TV Model LH55BEAHLGKXXU - Smarthub appears to be frozen
(Topic created on: 15-12-2024 10:34 AM)
Neom
Hi all
My first post.
I have a Samsung Business TV at home.
Unboxed it, ran the setup including a software update to version T-KSU2EDEUC-2220.9
All working fine except Smarthub.
When I click APPS and go into SmartHub (after logging into my Samsung account), I'm presented with a screen showing the preinstalled apps and nothing else. I can't click anywhere, the screen just seems frozen. Cant get to the search function so cant install Netflix and other apps.
To date I have done the following:
1. Used the device features to check the TV and smartfeatures.
2. Reset Smarthub
3. Reset the TV several times.
4. Called Samsung UK support. The agent was clearly reading from a script and had me do a smarthub reset again before concluding I should just monitor the issue for now.
I'm want to try downgrading the firmware to see if that helps but I cannot find any previous firmware on the Samsung website - only manuals.
Please does anyone have any suggestions? It seems I'm stuck with a TV where the apps/Smarthub simply don't work.
Thank you.
Neom
Just an update if anyone else gets this issue.
After calling the business support team it would appear this model of TV has a limited amount of APPs available and that you cannot get Netflix or Amazon Prime. Annoying but thats just the way it is with this model.
I will use an Amazon Firestick as a work around.
1 REPLY 1
Neom
