15-01-2023 04:46 PM
Hi there, I have an issue with my brand new Samsung QE50Q80BATXXU Tv. When I watch sports, the ball at times flickers across the screen rather than being smooth. Is there a setting to fix this? My previous saying tv which was an older model never had this issue.
15-01-2023 04:47 PM
Here’s a video
15-01-2023 05:08 PM
@Tellis10: Can you try heading to Home > Settings > All Settings > Picture > Expert Settings > Picture Clarity Settings, and exploring your options from here to see if you notice an improvement? If not, can you confirm if you have access to Sky Sports HD and, if so, does the issue persists on that channel?
15-01-2023 05:46 PM
Hi Andrew, I tried playing around with these settings and can make it better but it still does it. It judders on both HD and normal versions of the channels unfortunately
16-01-2023 01:47 PM
Just to add that would say generally for sport best to have brightness contrast and sharpness a bit higher than defaults (though not maximum settings), however depends on preference and can be a bit of trial and error. I think Standard Mode usually works well ,this Tv may also well have the specialised Sports viewing Mode https://www.lifewire.com/best-picture-settings-for-samsung-4k-tv-4776573 Looks like adjusting the Auto Motion settings did not make enough of a difference.
Some further information in this article https://www.rtings.com/tv/reviews/samsung/q80-q80b-qled
14-04-2023 08:29 PM
Hi, I have just purchased this tv as the review for watching sports was great. However, when watching football on the HD channels or any channel the ball, players and anything moving fast seems to flicker and teleport. I have tried changing the settings per the above and can’t get it any better at all. Makes it really difficult to watch and is very annoying.
is there a fix or is this tv just terrible and the reviews false??
25-04-2023 07:20 PM
Hi guys any help here on the settings for watching sports on the Q80B. Currently one of the worst tvs I have ever watched sports on. Please help.
24-05-2024 06:06 PM
Hello ,I have recently bought a Q80c 65" . I face the same issue while watching sports. The Ball flickers badly and above that any sudden movements of jerks and jumping looks like cuts the image shorter or super imposes for a split second..please suggest if there is any fix. Otherwise how can Samsung peddle this TV in front of any UHD TV and demand almost above double the price than a UHD TV. Please help if anyone has found a fix.
2 weeks ago
