qe55q7fnat screen issue
(Topic created on: 26-11-2023 10:35 PM)
simo242
Hi so my qe55q7fnat tv has started playing up it first started as lines on the tv but now after say 2 minutes the tv screen will almost look like the screen has gone but I don't think this is the issue, I'm hoping someone can help me out before I waste money changing the one connect box and cable if it isn't that, i have attached a photo of the screen,
2 REPLIES 2
ChrisM
SuperStar
Hi @simo242
Does this happen on all sources? What other devices do you have connected to the one connect box, and have you tried disconnecting them?
dylancoady
Hi, I am having similar issues.
Just wondering did you find a solution or what you did. Thank you and best regards.
