Q70R vertical lines in centre of screen
(Topic created on: 21-02-2020 01:08 PM)
JamieG80
Hi,
I hope someone can assist.
I very recently purchased a Samsung Q70R and straight away noticed an issue. There are thick vertical stripes in the centre of the screen that run the full height of the TV, one that is slightly brighter than the rest of the display surrounded on each side by a darker stripe. Each of these three stripes are around 3 inches wide.
It appears in all picture modes and is particularly noticeable and distracting when the image is panning.
I would really appreciate some assistance with this, as i feel i have spent a lot of money on a TV that does not perform as advertised.
Many thanks in advanc
12 REPLIES 12
CarloL
Hotshot
Hey @JamieG80! Let's run a Picture Test now to better understand the reason behind this issue: Press the Menu button > Support > Self Diagnosis > Picture test > Follow the on-screen instructions to complete the Picture Test. The image should be clear and free from any distortion. Is the image clear or still distorted?
JamieG80
Hi CarloL,
Thanks for the response.
I ran the picture test, and the issue i am having does not show in the three static images that it provides. The issue remains though.
I can provide images to try to better describe it if you wish?
Regards
Jamie
JamieG80
Hi,
I'd really appreciate a reply to the above as the issue i am having is still present and i'd very much like to know what can be done to resolve it.
Thanks again for you time.
Kind regards
AsadM
Hi JamieG80. It may be ideal for you to discuss this with our Technical Support as they'll be able to guide you further with this and if an engineer inspection is required, they can look into your available options, and help you arrange this. They can be contacted on 0333 000 0333.
MannyA
I am having the same exact issue vertical lines in the center of the screen and to the left and right of the screen. Only visible in panning shots with mostly solid colors. Especially visible while gaming. Samsung Q70r 65"
ChrisM
SuperStar
Hi @JamieG80 and @MannyA
We've just heard back from our TV/AV specialists on this who have stated that this is a normal characteristic of LCD panels and not a fault.
Hope this helps.
MannyA
Vertical banding is a manufacturing defect. It can arise due to multiple reasons. The biggest cause in LED TVs is the backlight.
McMacamac
Same here..
It's disappointing. I think it's because of the dimming zones. I'm about to sell it. No more Samsung.
MannyA
It's funny because everything was fine untill firmware updates. Currently on firmware 1356. Previous firmware updates added different settings on local dimming. So what's going on ?
