I have a question for the samsung LC24RG50FQUXEN
(Topic created on: 16-06-2020 05:26 PM)
osscarr
Does it tilt up and down instead of just staying the same. And does it come out of the box with 144hz, or do you have to do something in the system setting to get it to 144hz. I'm getting this as my first gaming monitor so yeah.
3 REPLIES 3
AndrewL
@osscarr: The monitor does indeed tilt on the stand - just make sure to hold the lower part of the stand and adjust the tilt carefully. To enable the maximum refresh rate, set FreeSync to Ultimate Engine or set Refresh Rate manually to 144 Hz. For more information, check out the user manual via the link below.
https://downloadcenter.samsung.com/content/UM/201906/20190621124500294/BN46-00996A-Eng.pdf
osscarr
thank you mate, it just looked like it didn't tilt beacuse it looks like it's screwed onto the actual monitor. That was critical to me knowing that beacuse I will place the monitor about 20cm above my keyboard and mouse so I will have to look upwards so it good that it tilts. One more question how much does it tilt down? sorry for another question.
AndrewL
@osscarr: You're welcome. Good question about the amount of tilt - it seems it tilts towards you by 2 degrees, and away from you by 20 degrees. For a better understanding, check out page 13 of the user manual as it provides a useful graphic to highlight this.
