Why no 77 inch QD-OLED for EU/GER and when 4K240Hz? (asking the real questions)
(Topic created on: 17-04-2025 08:20 PM)
Hello SAMSUNG,
really unfortunate, I need QD-OLED + 144Hz (also, when 240Hz? (yes, it will use DSC because HDMI 2.1a only allows up to 144Hz)) + 77 inch:
Top range:
  • The S95C (2023) is glossy, BUT has a One Connect Box, which only supports 40 Gbit/s (=120Hz), instead of the full 48Gbit/s (=144Hz)
  • The S95D (2024) is matte, so it's out of question for me (and the rest of the specs don't matter at this point)
  • The S95F (2025) is matte again..
Mid range:
  • (S90C - this one I haven't seen the stats yet *glossy, 144Hz (48Gbit/s) and QD-OLED?*)
  • S90D is glossy, but the 77 inch version only comes with a W-OELD panel, not QD-OLED
  • S90F is glossy,  but the 77 inch version only comes with a W-OLED panel, not QD-OLED
Lower range:
  • S85D and S85F supposedly unfortunately all use WOLED panels
(Yes, the 65 inch ones use QD-OLED.)
Please, give us a QD-OLED panel in 77 inch (and in 83 if you want).
1 REPLY 1
Luke on YT has peeled off the matte coating on his S95D and S95F (and more and more known TV channels are talking about it). Perhaps I'll get a used one and do the same. Will the warranty be void?
SAMSUNG, just offer both [matte and glossy] variants to customers and let them decide (though, removing the plastic matte coating like Luke did might reveal an even glossier, purer, QD-OLED panel; time will tell if it's usable or too mirror-like).
With the possibility of peeling off matte plastic coating, the only missing thing is 240 Hz (for now, 360 Hz and more later).
