S90d question?
(Topic created on: 25-02-2025 02:14 PM)
dyslexic
Pathfinder
Does every modern s90D come with a Qd-oled panel bc I watched a 10 mouth old video said not every S90d comes with a Qd-oled panel and it said something in time the chance of having the the better panel is higher so is this true and if it is, is there a way of telling if I got it on my model or not? (my TV is arriving today so I just want to check)
6 REPLIES 6
johnz237
Samsung Members Star ★
Not every S90D has a QD-OLED panel. The 55,65 and 77 inch models generally do, but the smaller and larger sizes use WOLED panels. So, if your TV is one of the middle sizes, it is highly likely it is a QD-OLED.
in smaller sizes (like the 42-inch and 48-inch) and the largest 83 inch model, the S9OD uses WOLED (White OLED) panels, which are produced by LG Display
Before buying double check with who you're buying the item from.
What model/ size did you buy?
dyslexic
Pathfinder
I brought the 48 inch and i brought from amazon, that's a shame so I don't have it then 😒
dyslexic
Pathfinder
Thank for telling me
johnz237
You're welcome! Be sure to set this as resolved so people with the same question in the future can see the solution—three dots next to the solution. Have a blessed day.
Hasithadiaz
Hi I ordered 55 inch S90D
model no is QA55S90DAUXZN
Is this QD OLED or WOLED?
I orderd from Samsung Gulf Online Shop
DenM
That didn't help me. i checked with Samsung before I bought my 77" S90D. They told me it was a QD OLED panel. It arrived and it's a WOLED! Still trying to get it sorted after a month from first contacting them about it!
