New TV ui help?
(Topic created on: 25-02-2025 05:18 PM)
dyslexic
Navigator
I've brought the s90D upgrade from a 2021 Samsung TV I love the new TV but the UI!! is there a way to make it when you press home to not have it got to a full page but a sort of a floating bar a bit like this how it used to be and still see the majority of the images in the background^^
if there not is there a way to turn of the big ads it gives and romove the trending and news tabs etc... Its a £1500 TV for good sake
So it only shows the apps I have not the reset of this blot also I heard there's a new ui come to the tvs will the s90D get it??
Also tip for samsung designers the new Samsung solar remote is a lot worse than the old solar remote it's got sharp edges and lot less grippy, plus let be bind the Samsung TV Plus button to something else😭
2 REPLIES 2
johnz237
Legend
What id say is to go to the Samsung Members app, then to Support, then to Feedback? This will get your request to the right people
Unfortunately, there's generally no built-in option to revert to the older, floating bar-style home screen within the TV's settings. Samsung designs their OS with a unified experience in mind, and major UI changes are typically not user-customizable.
dyslexic
Navigator
Oh okay thank you I was just hoping there was a bit of customisable aspect and the original skin was just for the old folks
