Go to solution Solved
Remote question
(Topic created on: 20-03-2025 09:03 PM)
dyslexic
Pathfinder
I accidentally stood on my remote I'm I heard a crack thought the worst and then realized the glass on the back of it for the Solar has cracked just curious it's no big deal but has it broken Solar charging
TechZilla
Samsung Members Star ★
If the only thing cracked is the glass and not the solar panel beneath it then it should still work, it probably won't be as efficient as before and moisture etc might get inside and damage the panel over time, hope this helps.
TechZilla - Samsung Members Star
2 REPLIES 2
Ginga_p
Hotshot
I would imagine so you can still use the usb c though
G G
TechZilla
