Help with compatibility on recording live tv
(Topic created on: 02-06-2024 03:21 PM)
KRTRFXR
I only need to know what external device is compatible for recording live tv for 65" Class Samsung Neo QLED 4K QN90C that I just purchased
5 REPLIES 5
AndrewL
@KRTRFXR: For recording live TV, it is recommended to use a USB hard disk that supports USB 2.0 or later and 5,400 rpm or higher. RAID-type USB hard drives and USB memory sticks are not supported. For further information, please take a look at page 180 of the user manual by following the link below.
https://downloadcenter.samsung.com/content/UM/202404/20240426190921443/BN81-24055C-460_EM_OSPDVBEUC_...
KRTRFXR
I did see this, however I am having a hard time finding something that fits this description when shopping. I am looking on say Amazon. Do you have any suggestions, that are cost effective?
JAMES4578
Samsung Members Star ★★
You will find Some compatible Drives in this article  here, 500 GB should be fine and it is  recommended not to use a Hard Drive with more than 2 TB  capacity.   https://www.bestproductsreviews.co.uk/external-hard-drive-for-samsung-tv-recording/
KRTRFXR
Thank you! I will look into these!
JAMES4578
No problem, hopefully can find something suitable.
