03-06-2022 07:54 PM in
TVHi I have a Samsung TV model UE32T4300AK I brought a Bluetooth transmitter so I could use my headphones but this hasn't worked. I only have TV speaker and optical available on settings. I've even tried plugging headphones in usb but to no avail. I have the red and white audio on back of tv and this doesn't work either..
03-06-2022 08:19 PM in
TV@Shorty73: You won't need a Bluetooth transmitter to connect your headphones to this TV. If you place the headphones in pairing mode by following the manufacturers instructions, then head to Settings > Sound > Sound Output > Bluetooth Speaker List, and select them from here. If the TV fails to find them, place them closer to the TV, then hit 'Refresh'. If the problem persists, can you confirm if you have successfully paired the headphones to another compatible device? Also, do you have another pair of headphones that you can try, just in case there is a compatibility issue with the current set?
03-06-2022 10:33 PM in
TV
