Compatibilty with pioneer receiver
(Topic created on: 04-10-2018 02:32 AM)
Billyt1
I have directv box, pioneer elite receiver and Samsung tv.
Problem is, when I connect everything to my receiver through hdmi, every time I turn my tv on, I get a message saying no signal. It works if I turn my receiver on. My receiver has hdmi pass through, nevertheless it should work without turning my receiver on. When I turn it off, the tv will display directv until i turn my tv off. Then I turn tv back on, same result, no signal. Compatibility issues with cec? My luck, probably
5 REPLIES 5
CarlH
Maestro
Hi @Billyt1. Can you tell me the full model number of your TV?
Billyt1
Hi Carl, thanks for asking. My model is pn59d6500df.
I appreciate any feedback you may have.
ChrisM
SuperStar
Hi, @Billyt1.
Have you tried a different HDMI cable to see if that could be causing the issue?
Billyt1
Hi, yes I went and purchased new cables. More on the high end hdmi cables. Thanks!
Zoli3
Same problem, but i have mu6102khhx with pioneer receiver and hdmi 2.0 cable.  I see tv port arc text and receiver supplier arc function but not working. I tried other tv, perfect worked.
what is the problem?
