15-05-2021 09:21 PM in
TVI've just bought a Q70T TV and I'm having some troubles with the remote - I wonder if anyone knows how this is supposed to work:
I've connected a Pioneer receiver through optical input and added it as a device in the remote configuration. While doing through those steps there was a power test where the TV (remote) was testing if it could turn off/on the receiver - and it could! The problem is that it only does that during the configuration and never otherwise, so pressing the power button on the remote does not turn on or off the receiver... Is there a way to achieve that? I was under the impression that I would be able to use only one remote...
29-08-2021 06:38 PM in
TVHey have you ever sorted it out? I have same problem with my onkyo... Its anoying to have to turn it on and off with 2 remotes and indeed it does work in the setup... is there any way to program it or so?
01-03-2022 02:20 PM in
TVHave the exact same problem with my Samsung AUE60 TV, it turns on/off the receiver during setup but never once set, it only controls the volume from that point, should be an easy fix!
12-07-2022 07:22 PM in
TVI recommend buying LG or Sony tvs… worked for me on a new Sony
23-08-2022 10:26 PM in
TVDid you ever figure it out? I have the same problem: https://eu.community.samsung.com/t5/tv/samsung-qn85a-not-turning-on-off-sound-system-using-universal...
24-08-2022 07:12 AM in
TVOfc not did zou not see my chat with samsung.. 😂😂 there is no fix just waiting to buy a sony or lg in 2023
