Go to solution Solved
Blurry on left side of tv
(Topic created on: 08-03-2020 09:35 PM)
SianMilton12
I dropped my remote of my Samsung smart tv today and now the picture is blurred on the left hand side. I've done a picture test and reset picture settings but it's still the same. It's not on the menu or home pages of programmes only on the tv programmes themselves.
AndrewL
@SianMilton12: Sorry to hear that you have experienced this issue. Can you try switching off the TV, unplugging it at the mains for a minute or 2, then plugging it back in to see if this resolves the issue? If not, can you confirm if you have an external device connected to the TV, and if the problem occurs on all channels?
6 REPLIES 6
AndrewL
SianMilton12
I have unplugged and plugged my tv back in and it has restored to normal. Thank you for your help
Adng23
Thanks, this also solved my tv problem too.
gpellegrini
Thanks, solved mine too.
vigogo
did not work for me
Dan1886
Yes, this worked for me, thankyou
