Samsung fridge freezer adjustable leg issues
(Topic created on: 22-05-2020 08:02 PM)
Rich1966
Hi everyone,
Really bizarre but bought a Samsung fridge freezer, model number RB29FSRNDBC, and the right leg just won't adjust. It has the wheels on the back and two adjustable legs on the front.
When I unpacked it and lifted it off the polystyrene the right leg fell out and it's almost impossible to get back in. I finally managed it but it only turns very slightly before being completely stuck - so no adjustment. The left one is fine. Spoke to Samsung support and then said that the right one isn't adjustable, it's supposed to stop after a few turns, but surely this can't be the case as you would have no chance of levelling  front to back.
Any ideas would be appreciated.
Many thanks.
4 REPLIES 4
ChrisM
SuperStar
Hi @Rich1966
This doesn't sound quite right! We've had a quick look at the user manual (page 18 here), and this does refer to being able to adjust both front feet of the Fridge Freezer.
You can reach out to one of our DA Experts for further support at https://www.samsung.com/uk/support/contact/, who can offer further troubleshooting at this time. This being said, at the moment, due to the impact of COVID-19, our customer support team is operating at a reduced capacity and we will only be repairing products with faults deemed essential. We thank you for your understanding and apologise for any inconvenience.
 We appreciate your patience, please keep checking our COVID-19 update at https://www.samsung.com/uk/covid-19-update/
Rich1966
@ChrisM wrote:
Hi @Rich1966
Thanks Chris, I think I'll reach out as it's pretty essential as I can't use it at all. Many thanks.
ChrisM
SuperStar
No problem @Rich1966. Didn't know if you might have found a temporary workaround.
Hope you get it sorted and have a great weekend!
Chris.
Tejinder
Bought a fridge freezer model RL38C776ASR
both levelling legs won’t turn as per manual instructions on page 33. It say use screwdriver. Tried failed called Samsung   I was told I need a spanner supplied by them which I did not find in any packaging.
looking at the legs looks like no room for that spanner .
could I get some help or advise
thakns
