S24 Ultra Battery Drain Issue
(Topic created on: 17-02-2024 12:16 PM)
Billymayn
Voyager
All,
Update:
I was struggling with poor battery on my S24 Ultra and was even thinking to return it. After some research online I decided to reset my phone to factory and set it up fresh. I did not use smartswitch this time and now I can confirm that the battery just wont die... 😅
So anyone struggling with battery try the above. I know it is a pain installing all the apps again if not using smartswitch, but it is worth it!!
115 REPLIES 115
Da6xn9
Pathfinder
Hopefully samsung fixes this
BandOfBrothers
It has come to light in the past that for some using the SmartSwitch option to set up their new phone's has caused some hiccups.
Personally I use my Samsung Cloud Backup to transfer my info over, and only use SmartSwitch to move across my Gallery.
The Device Care Section under Battery can also help to highlight what is using the battery too @Billymayn
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Reylob
Samsung Members Star ★
I agree, it is a pain to set the phone as new, but it is worth it. I always set my phones as new and the set the apps as needed.
It makes the phone run smoother.
Saying that, battery is the one thing that really improves after the phone ends the learning period and settles.
Technology enthusiast, but not related to any technological company.
Billymayn
Voyager
Yeah also you get rid of all the apps you don't use because you are installing only the ones you require on day to day basis
MRM7
I noticed strange battery drain after a couple of days. Checked the battery settings and it was an app causing it. Force stopped the app and it was all good after that. Interesting if smart switch is the culprit
Billymayn
Voyager
Well after my experience i certainly do. I did keep an eye on battery settings for any apps draining but everything felt normal.
I guess when u use smartswitch it brings in all the corrupt settings and cache with it.
S24 ultra2
Hi brother I bought s24 ultra 2 days ago my phone just give me 6 hour screen on I was watching videos they had 11 or 12 hours screen on I didn't used smart switch how I can solve my issues
BandOfBrothers
Viewing videos via YouTube or Ticktock etc will drain the battery faster due to the resources they use @S24 ultra2
Have a look in your Device Care Section under Battery to see what's using your battery.
The battery will improve by optimising once it's been charged and discharged a few times and the optimisation has compelled after 1~2 Weeks.
S24 ultra2
Brother I see battery usage per app I had some counting I just used 30% in apps but battery drained 80% is that ok?
