S24 Ultra Battery Drain Issue
(Topic created on: 17-02-2024 12:16 PM)
Billymayn
Voyager
All,
Update:
I was struggling with poor battery on my S24 Ultra and was even thinking to return it. After some research online I decided to reset my phone to factory and set it up fresh. I did not use smartswitch this time and now I can confirm that the battery just wont die... 😅
So anyone struggling with battery try the above. I know it is a pain installing all the apps again if not using smartswitch, but it is worth it!!
115 REPLIES 115
Billymayn
Voyager
You are getting 6h 30mins with 25% battery left. If you let it die you may get 8 hrs. Which is great
Billymayn
Voyager
What are the issues u facing? Battery?
Try factory reset and don't use smartswitch.
jhigchvkh
Navigator
Does that really works ? 5 cycles of 100 to 0
S24 ultra2
Yes that will work now after 1 week and 10 cycle I get 9 hour screen time in 28 hour of usage
Billymayn
Voyager
When you say one cycle do u mean use it till it turns off?
Billymayn
Voyager
From 100 to 0
S24 ultra2
No not 100 to 0  some times charge and discharge 100 to 5 percent and charge again 5 time I mean you must wait for one or two weeks
Dineshballer
I was very skeptical to do a factory reset but still went with it. I took a backup with my external hard disk with Samsung back up and reset my phone.
Now I feel like I have a brand new phone. My phone is no longer draining battery and everything seems to be okay. I no longer have to charge my phone twice a day.
If anyone is having the same battery issue I would suggest take a backup on your hard disk. Just connect a drive to your phone with USB C and go to setting search for back up with external drive and just back up all you need. Once resetted, connect the drive again and restore from the same setting.
kefacool
This worked out for me
Ashique 95
Great bro 💯 how many hours of screen on time you are getting now ? And which mode you are using?  I get today 9 hours but before it was near to 6 hours . I bought 7 days ago
