Overheating + Battery Drain solution – For when i have no signal
(Topic created on: 11-07-2025 10:52 AM)
benakaget
Voyager
Galaxy S24.
The gym i go to has terrible signal, so it's constantly searching for 5g, 4g...etc.
When I take my phone out my locker, after its been in there for 2ish hours, its roasting hot and lost like 25% battery.
What can I do to stop the overheating and drain in this situation
#benakaget
4 REPLIES 4
keith30
Legend
Swich it off then till you leave the gym.
MNas04
Samsung Members Star ★
You need to ensure the area of the gym where you put your belongings has a cool temperature. Leaving your phone data on and searching for a signal will use a lot of your phone battery and will cause it to overheat. To prevent it from happening again, consider reducing your phone brightness and not leaving your data on whilst in your locker.
benakaget
Voyager
Should I just put it in aeroplane mode then?
MNas04
It's up to you to decide. If you don't want it to overheat, then yes. Make sure you close background apps regularly to stop them from using your phone battery. If you have Bluetooth enabled, turn it off if you don't use it that often or temporarily.
