Go to solution Solved
Help - can't set incoming notification sound for Google messages (or for some other apps)
(Topic created on: 24-01-2024 04:06 PM)
blenky
Troubleshooter
Hi, on my S23U I had a specific sound set for incoming messages.  I use Google message and not Samsung app.  I'm just setting up my S24U and cannot see option to set specific sound.  I attach two screen shots.  One is the notification app screen for google messenger on the S23U.  You can see the selection 'Notification categories'.  This is where you select a specific incoming sound for texts.  The second screen shot is from my S24U - note the lack of this option.
The Configure in Messages takes you back to the app but there is nowhere in app settings to set incoming message sound.
Can anyone help?
S23US23US24US24U
Go to solution
38 REPLIES 38
AntS
Hi guys,
Just a post to say that I've merged a few threads that appear to cover pretty much the same thing here.
Calv
Pioneer
I've been advised it's a software issue and a update is being released next week. I have the same issue as can't change ring doorbell or Google messege apps tones
AndrewD71
I think I have the answer to this, from Settings go to Notifications/Advanced settings and toggle on 'Manage notification settings for each app'. The notification category option is then available.
blenky
Troubleshooter
Well done! Nice find. Checked my S23U where this is not an option. New in One UI 6.1. Should be on by default!
Calv
Pioneer
Found the fix for this issue. There hidden feature
Calv
Pioneer
Under notifications you will need to switch on this option on highlighted1706263100874.jpg
LMB830
This worked for me.  Thank you!
mcharlton1969
I have a similar issue on my S24, I'm unable to change notification sound settings for apps. I hope this is fixed soon as it is extremely annoying
blenky
Troubleshooter
Read the posts a few up from yours, which have the solution!
mcharlton1969
It doesn't have the solution for me, I already looked. Those options mentioned are not available on my phone
