Go to solution Solved
Help - can't set incoming notification sound for Google messages (or for some other apps)
(Topic created on: 24-01-2024 04:06 PM)
blenky
Troubleshooter
Hi, on my S23U I had a specific sound set for incoming messages.  I use Google message and not Samsung app.  I'm just setting up my S24U and cannot see option to set specific sound.  I attach two screen shots.  One is the notification app screen for google messenger on the S23U.  You can see the selection 'Notification categories'.  This is where you select a specific incoming sound for texts.  The second screen shot is from my S24U - note the lack of this option.
The Configure in Messages takes you back to the app but there is nowhere in app settings to set incoming message sound.
Can anyone help?
S23US23US24US24U
AndrewD71
I think I have the answer to this, from Settings go to Notifications/Advanced settings and toggle on 'Manage notification settings for each app'. The notification category option is then available.
38 REPLIES 38
keith30
Legend
They did that with some of the apps iv'e noticed. Same thing happend when i moved from the S8+ to my latest model the S22ultra and most of the sounds were completely different to what I was used to.
Calv
Pioneer
Hi all I've just got my S24 ultra. I cant seem to assign a different tone to notifications on my Google messages and ring door bell app. All my tomes are just the system tone. On my S23 I could change it but looking at the settings on the s24 there different. Anyway of changing these please !!
Calv
Pioneer
I'm having the same issue as got my s24 ultra today and can't change my messages and ring door bell tones
Ynot68
Apparently it's a software issue and I have been told that a fix update will come next week. I chose to send mine back for a replacement as not all handsets are affected
BandOfBrothers
Is there options via Settings > Apps > Choose App > Look there for any options to change the tone @Calv
 The only other section is the sounds and vibration section.
Unfortunately there maybe some tones you can't change as ker the developers preference settings.
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Calv
Pioneer
These are the only options. On a forum there was talk of it was a software issue affecting some phones and an update is meant to be released next week 1706186023051.jpg
Andy31370
Could someone please help...... I am unable to set notification tones on my New Galaxy S24+. I can set the main notification tone but I cannot set tones for other apps, for example Samsung Messsges. I have no options to change notification settings.
BandOfBrothers
@Andy31370
Look in Settings > Apps > Choose App > Look to chabge the tones there.
Andy31370
Thanks, but no option there
