Go to solution Solved
S23 Ultra problem with all camera modules in zoom mode
(Topic created on: 27-07-2024 09:28 PM)
Igoryanchik
20240713_155526.jpg20240713_155533.jpg20240713_155701.jpg20240720_160712.jpg20240719_121102.jpg20240719_121049.jpg20240713_124038.jpg20240713_155540.jpg20240719_120553.jpg
Igoryanchik
When changing the scale, the quality is lost, objects start to pixelate, cropping appears, the situation is the same on other similar devices, I looked at the same device C 23 Ultra in the store, there is no such problem there.
I contacted the Samsung ASC, they did not find any problems with the cameras, they said everything works fine.
Other users also do not have the image spoiled when changing the scale
Cover Assistant is installed, everything is set to maximum quality!
3 REPLIES 3
justarandomperson
Pathfinder
What is the problem
Igoryanchik
slytherinz
Normal as it can only capture a decent photo at its lens value meaning it is only great at x1 x.6 x3 and x10 going over that values and you only stretch the photo captured on its original lens size. It will result to a blurry image and you just use remaster to have software improve it.
