07-01-2025 07:28 PM
Dear Samsung Community,
It has come to my attention, and that of many other users, that the Samsung Galaxy S22 Ultra, particularly those with Exynos 2200 processors, is experiencing severe hardware failures following the One UI updates. These phones are being rendered completely unusable, stuck in a booting loop, and unable to power on.
Overheating Leading to Motherboard Failure:
One UI Update Triggering Failures:
Warranty Expiration Problem:
No Official Acknowledgment from Samsung:
As a dedicated Samsung Galaxy S22 Ultra user, I, like many others, invested significant time and money in purchasing this flagship device. For example, I personally pre-ordered the phone, waited four months for delivery, and paid approximately €1,450. I expected a premium product, not a device that fails due to a software update and poor hardware design.
Therefore, I urge all Samsung Galaxy S22 Ultra users facing similar issues to:
Samsung must acknowledge that their software updates directly contributed to the motherboard failures. It is unacceptable that users are left to bear the costs of repairing or replacing a flagship device due to Samsung’s oversight.
Together, we can amplify our voices and ensure that Samsung takes responsibility for this issue. It is time for them to address the concerns of their loyal customers who trusted them to deliver a reliable product.
Let’s work together to bring this matter to the attention of Samsung’s leadership. Every affected user deserves resolution, not silence.
Best regards,
[A Concerned Samsung Galaxy S22 Ultra User]
26-03-2025 12:09 PM - last edited 26-03-2025 12:10 PM
04-04-2025 10:20 PM - last edited 04-04-2025 10:25 PM
Greetings, first post so be gentle if repeated.
I had the same issue on my 2 year old ultra 22S bought new from samsung after march security update. i think it is a motherboard issue as it does get hot unnecessarily after update.
There is an excellent app called Device info HW with will list all parameters of the device including cpu temps.
I have the Snapdragon8 Gen 1 chipset.
My solution , I tried safe mode . nope.
I got a clue on a reboot when it asked me which launcher i wanted to use, the Samsshit launcher is not compatible with this update or one of my apps. It disabled the nova luncher in one reboot but once i got it to take it has been stable in airplane with wifi.
So, I am using Nova 7 launcher with airplane for now so that I can get my data off to a new phone. So far, no crashing until I take my device out of airplane mode.
All apps seem to be working except cellphone related, obviously.
I hope this helps someone else to get data off the device to a new one.
This is very disappointing after owning more than 10 Samsung flagship phones.
I started reading about the new S25 and ill pass with all the problems it is having.
I will not be getting the 25, maybe the older 24 after some research.
KK
15-04-2025 06:49 PM
Hi,
I agree with you. There should be more we can do. I am not sure this is coincidence. I just paid off my device with 02 network fully. It costed me £1185. 2 days after I got my update notification and my phone started rebutting itself. I bought the phone in Jul 2023. It is discussing that the organisation takes no responsibility for this. With that being said I also think that Samsung Web is not necessarily correct forum to address this. I think this will need to go public via other media then this Web. Most of people with this issue may not be able to access this forum :(. I think that the brand quality is decreasing drastically and no longer provides good value for the money.
I used to value this brand and I therefore own and owned multiple products over the past 20 years. This will not continue. I can also assure you that I will no longer use the brand. My my kitchen oven didn't even make it till the end of the warranty before panel stopped working and when the company reps came to fix it with new panel, wifi was already gone on the new one :(. This also did not last since the repair.
I have just received 6.1 update notification on my Samsung Galaxy Tab S9 Plus tablet and I rejected it, because at this stage I am terrified that this will leave me with no mobile device to use.
I also found 6.1 update causing the same issue for the tablet on this web :A9+ tablet issues after 6.1 update - Samsung Community
I am now convinced that this is linked to the company marketing plan. I don't believe in this being coincidence.
The company must take the responsibility. Those of you who paid by credit card or loan my be able to get through this with financial ombudsman. I am not so lucky anymore. It may be worth considering Consumer Rights: Consumer rights - GOV.UK
I hope this helps someone.
20-04-2025 08:46 PM - last edited 20-04-2025 08:48 PM
20-04-2025 08:57 PM
Sorry to hear of your bad luck. I was able using my method to get my data off the device and foolishly. I went up to the Galaxy. S25 ultra, because it is running the current operating system. Furthermore, the new Galaxy's are doing a partition drive. When they do update so they don't have this problem. Which is a very interesting solution? I don't think the 24 or earlier has that feature? I think they recognize now this is a big problem and the updates for 1 UI 7 have been delayed repeatedly when they have a stable release for my old phone, the Galaxy 22 ultra. I will do the update and pray that it gets rid of the constant on off cycle. If not, I will be factory, resetting it and then I hope it will work again.
20-04-2025 09:01 PM
20-04-2025 09:04 PM - last edited 20-04-2025 09:06 PM
I have done the same trick by putting the phone in the refrigerator and it works until the device gets to room temperature. However, I do believe there is also a problem with the apps conflicting with the March update, and the Nova. 7 launcher keeps it working
longer before it starts to crash. I'm glad
you got your data off. It's a drag that you
didn't have it paid off. Luckily, I'd buy my
phones in full beforehand and this purchase from Samsung directly in u. S.A. I got Samsung care and I bought it from them directly. So that if there's a problem, they can eat the phone
28-04-2025 12:08 PM
My Phone is Dead after Regular Update and when i Reach the store they said Motherboard Failure . Finally Left the Samsung behind and moved to Apple . Lost the Trust on Samsung .
29-04-2025 11:56 PM
Me acaba de ocurrir un s22 ultra de la nada después del parche de una actualización se fue a negro, luego al tratar de reiniciarlo se puso un pantalla celeste, lo lleve a samsung, pero como esta fuera de garantía me hicieron pagar por una evaluación ya que en primera instancia no lograron recuperar el sistema, más encima que uno pierde toda su información, te indican que podría ser la placa base y que tiene un costo aproximado de 300 dólares, son teléfonos bastantes caros para que simplemente Sams7ng se haga el desentendido, no es posible que despues de una actualización simplemente los telefonoa se mueran o es que buscan que uno obligadamente tenga que renovarlo????
27-06-2025 02:54 PM
I also faced this issue on my S22 ultra. Firstly My device was starting freezing and restarting randomly like 2 to 3 times a day. Then suddenly one day it continuously restarting itslef again and again like 8 to 10 times and after that phone never switched on. I faced this issue after updating it to One Ui 7 and may security update before that i was using my device perfectly, there was no single issue regarding anything.
I visited the service center and after 2 days they told me that there is motherboard fault and battery fault on my device, and repairing cost is 44 k aprrox.
I just got frusted after listening it, i mean whose fult it was, Since this issue occured after updating it One UI 7
samsung should take responsibility about this we payed lots of money and it was your falgship device., samsung cannot deny just saying that your device is out of warranty.
I want my device back to normal since it was not my fault otherwise i have to take action against samsung.
This is unethical
